hi all , does anyone in EU, to have for sale this wheel model , Evolve 150 mm with inner
, And 12S chearger 3 or 4 A??? And sensor wire extension !I have a 12s charger for sale, almost new.
I’ll take pictures if you are interested.
7 A , is not to big ??
I’m interested
Depends on your pack, 30Q cells are rated for 4A charging max, so if you have a 2p pack you can go 8A easily
I’ll take some pictures tomorrow, have it at work
yes , 12s 4p ,30q
someone have ???
Wouldn’t charge a 2P at 8A lol
For safety, go about 75%of your rated limit. So 2p would be more 6a
I would never charge a 2P pack at 8A lmao. I charge in regards to the P groups for 30Q. 4P 4A, 3P 3A. I’m going 6P and will only use 6A charger for “fast” charging and 2A at home.
Those tyres are brand new and sold out most places immediately I believe. What wheel are you using? It needs to be the Evolve or equivalent because the hub is slightly bigger.
Just checking you know
You are suggesting as a “fast” charger to use only 25% of your possible charging capacity? Wouldnt that be the “slow” option?
i buy just a 30 minutes before , 4 pieces , sow it will be 150 mm wheel
and i will use with trampa superstar
I try and charge at 2A as much as possible. I know its probably retarded but that’s just me. I don’t ever use my any other charger except for group rides or when i forgot to charge the night before. (I use my board to get to work.)
No thats perfect
That’s perfect
@ThermalChild @Sebas @Flasher , i have a power supply 54 v, 5 A , it’s good
to charge the 12s 4p Pack ??
@Lazea If your wires are big enough, sure. Your batteries can technically go up to 16a. Dont do such a thing but they can.
