This board just isn’t for me. You can see why in the build thread for it: The Prince | 12s10p flight-safe Idea deck build
Description
With TKP trucks and a flexy deck, this board is very fun to ride! The trucks are also stable up to 33mph (though on this deck I wouldn’t recommend going that fast). If you buy this, you could either ride it with a top box setup like I did for massive range, or build a small 12s2p or 3p to put in the front for a super sleek-looking ultra board! Or, just part it out, because these parts are very versatile.
The drives can support up to 6384 motors on these trucks, but I chose to use 2x 6355 ones forward mounted, because then you can drag the board by its front, and the motors always stay protected ![]()
The board is currently lacking an ESC, because the two Trampa VESC 6 mk3 I was using would sometimes desync from the motors and cause oscillations. (I know this doesn’t happen with other ESCs I’ve used with this build) If someone is interested in a fully complete and rideable complete board, then I can supply a Stormcore 60D+ or a Maker X DV6 pro with it + a chrome puck remote.
Specs:
- Deck: Idea flex 2 (unobtainium) with 2cm flat drop brackets
- Trucks: 3DS HeXL clone hangers with HeXL split-angle baseplates. (unobtainium) 8mm titanium axles.
- Bushings: Can modify depending on your weight, currently using green tall krank barrels in the rear, and a purple tall krank fatcone and tall lime aps barrel in the front.
- Drivetrain: 3ds Fatboy mini helical 1:4 ratio with 3ds CNC aluminum hubs in black. NSK bearings.
- Battery: 12s10p Molicel P26a. 26Wh, ~1.1k Wh.
- Tires: Trampa Urban Treads
- Motors: Maytech 6355 190kv motors with 8mm round shafts.
- Enclosure: Old eboosted fiberglass enclosure cut down to only house an ESC + accessories.
- Footstops: Newbee chrome in the rear, Riptide purple aero in the front. Can also supply an orange single-bolt CNC toe-stop from Skoa.
- Remote: Hoyt Puck in chrome finish
You can also buy the 12s10p P26A flight-safe modular battery + hardshell Nanuk case I used with this board. Pictures of the battery building process also available in the original build thread.
Top speed: 53km/h
Range: 55km
More pictures
Prices
Ideally I’d want to sell this as a complete, but if that fails, then at least deck + drivetrain together. Failing that, as parts. If multiple people call dibs on different parts, we can do that straight away ![]()
- Complete board with an ESC + battery + remote: 1400€
- Complete board WITHOUT ESC + battery + remote: 1200€
- Complete board WITHOUT ESC, WITHOUT battery, WITHOUT remote: 550€
- 12s10p battery: 600€
- Deck + brackets + enclosure: 200€
- Drivetrain (trucks + drives + motors + wheels + tires): 400€
- Footstops: 20€ each
- Remote + receiver: 150€ (If you buy smth else)
Can only ship battery within the EU, but everything else world-wide. Though if you really want the battery I could fly myself to you with it, since it is flight-safe after all ![]()
