Esk8 Retirement-BMS’s, Wheels/Tires, Trucks, Decks, Bindings, Stormcore 60d+ (2), Heatsinks8o
Subject: [US-Selling Everything]
*I am working on getting everything posted. Everything in photos is for sale. If I forget something or you have inquiries, just message me. There is some wiggle room on the price of some of the items.
Item 1
Description: 12s5p P42A 21700 Battery Pack built by @A13XR3 with smart BMS. It’s really good quality and I paid $700 for it new. It has a little black sealant on the shrink wrap, but it doesn’t affect anything at all. I don’t have the BMS app anymore, but I’d estimate that there have only been 20 charge cycles on it. It is currently in a beat up pelican case that has xt90 output port and LP 20 2 pin charging port. I am also selling the gray pelican case with the same charging port and output and an Apex Custom 12s smart BMS, all wired in. Both cases are a little ugly but function well. They were modified with quick connect pins on the bottom to fit both of my decks.
Price (USD): Battery: no case ($500+shipping), Battery with Black case ($520+shipping) Grey pelican case+BMS ($45)
  • upload pictures here
Item 2
Description: 12S BMS’s
Price (USD): $15 per + shipping
Item 3
Description-Gt2b Remotes (2). Could use new 3d printed cases, but both have worked great for me
Price- $50+ shipping each
Item 4
Description-72 Tooth Aluminum Pulley. MBS Rockstar II Bolt pattern. I didn’t use them for very long before I switched to chain drive. They have a little wear and tear, but are otherwise in great shape.
Price- $50+shipping for set
Item 5
Description: Trampa Primo Striker Tires 9” (lots of tread left)
Price: $50 for all 4.
Item 6
Description- Boardnamics ABEC wheel adapters. Ridden maybe 5 miles before I switched wheels
Also:Boardnamics kegel adapters (not pictured yet because they are still installed)
Price- ABEC Adapter $30+shipping for the set
SOLD-Kegel $25 + shipping for the set
Item 7
Description-Verreal Mads Wheels-105mmx65mm 72a durometer. The lettering is wearing a little on the side, but these wheels are in otherwise great condition and have a ton of life left.
Price: $100 + shipping
Item 8
Description- SOLD-Boarndnamics 220mm Hangers with Paris Baseplates, I don’t recall what brand the bushings are, I just remember buying a nice set.
Price $115+shipping
Item 9
Description- Reacher 63100 140kv sensored Motors. 8mm shaft (they were cut shorter to work with my gear drive, so you may need to put new ones in depending on your usage case. I believe both Hall Sensors are still functional. If not, HFI will still work great.
Price-$130 for both + shipping
Item 10
Description- Stormcore 60d+ (2) Neither have been used much (less than 40 miles on each). They look messy because they are still in their enclosures and have some hot glue, sealant, and residual thermal putty on them, but they are perfectly functional. I can clean them up before shipping them. One of the Vesc’s doesn’t have the + labeled. When I talked to Lacroix about it (my order was for the 60D+) , they assured me it was a + but that the batch it came from didn’t it have it printed on the VESC. If you buy this one and it turns out to be the 60d+, I will reimburse the difference in the price (would have to show me that it is indeed the 60D, whether it be through software or difference in components).
Price: $200 each
May be interested in some of the drive train components. Base plates, Motor Mounts, Motors…
Can you tell me about them? And what you would want?
Which ones are you interested in? The mountain board has MBS Matrix 2 trucks with aluminum baseplates ( the rear one was heavily modified and reinforced so that I could run larger motors).
It also has the Boardnamics M1-AT gear drive. Unfortunately some parts of it are heavily messed with/not good anymore. Just let me know if you need parts from it and I’ll see if whatever you want is still good.
The motors are Reacher 63100 140kv with 8mm shaft. I had to cut them shorter to make them work with the gear drive.
The trucks and baseplate on the street board have just been listed on the post.
The motors are Turnigy 197kv 6374. They have some holes I drilled in the can for airflow (debris could potentially get in them, but don’t believe this has happened yet. They are a little ugly (I don’t personally care about that ), but could be made to look nice. They have been rock solid for me.
Message sent.
If dibs weren’t called on the reachers, Ill snag em.
Sweet. They are yours. What’s your address so i can calculate shipping for you?
FYI, these probably need a price drop. these are $40 new on amazon. (tho they also need a new case. )
but more importantly. Bump. GLWS.
You ever get rid of the reachers and stormcores?
Reachers are gone, but I still have the stormcores. My bad on the delay.
