That go kart track is actually pretty cool. No doubt about it. The problem is that we donât get access to it other than for esk8 racing events, which is 1-2 times a year.
I definitely recommend it. And it doesnât require much. You just need GoPro 5 or newer (maybe not too new; those have some issues) and install RaceChrono.
I think the track size wasnât the issue, yet it wasnât easy to overtake. This was mainly due to how even the race was. If youâre significantly faster than the guy ahead of you, itâs easy to overtake. If you are barely faster though, itâs challenging, especially when the guy ahead of you sticks to the optimal path.
Weâve talked about this with guys and one idea is to have a joker lap as in the rally cross. Once in the race, each racer needs to take an extended route. That opens more opportunities for changing the standings.
Thatâs pretty intense, sounds like an hour of work per board at least
Is this similar to what would happen for gokarting?
In lieu of the point of the thread, there are a lot of things in your comments that make sense to have checked. Maybe there would be some kind of way to have the riders pre-check some things, like submit their pulley / gear tooth count before, mark it with some kind of identification, and then compare at the race.
Max top speed is an interesting concept, would it be defined in different classes? EG 30mph class, 40mph class, 50+?
Can we even reach those speeds on track? What are reasonable speed limits?
Jason, this is more suited to professional racing where there is a lot of sponsor $ involved and millions of viewers. I do not think we are there yet, It needs to be simple and easy for the competitor and the organizer!
yeah dude, the races are super casual and theyâre agility races. the highest speed youâre going to hit is maybe 16mph, so even a 6s board can hit those speeds. The only thing we would be considering is the type of trucks theyâre using as trampa style trucks and DKP are at a huge advantage.
This sounds overcomplicated. I believe a better way to create even conditions is to build the track such that board setup becomes less of a factor. In particular, make it such that nobody is able to reach their top speed.
T-race is a good example. You canât get above 40 km/h. Acceleration helps a little but the way youâre going around the cones is still the major factor. Itâs primarily about the rider, not about the board (I mean as long as itâs not the first generation Boosted).
perhaps just tell everyone that to race they need a metr / robogotchi on the board
afterwards you have to show logs proving you never went over the max speed / watts / amps / volts that you said
because in theory people can cheat with the metr settings on speed (different pulley counts) you could get them to put a basic gps speedometer in their pockets also
or maybe metr has a gps speed setting (not sure?)
I mean, this would work for our first race as everyone had some sort of DIY (Flux, kaly, and actual DIYs) but we had an evolve, ownboard zeus, and a backfire hammer last weekend. wouldnât work.
