Esk8 confessional
What’s up your ass, dude? :joy:
Negative Nancy to the max, sheesh.
My guys claiming he can practically go high way speeds on a euc
And no I don’t actually wish him physical harm.
it’s 24s4p combined, that euc is kinda the size of a small travel suitcase. it fits
the wheel practically approaches the rolling resistance of a road bike wheel, and there’s only one of them
He certainly can… Ever see the upper echelon offered by Gotway? They can blast a top tier esk8 out of the water in terms of speed, torque and maneuverability.
Look up Trishawn F… Something…
‘Trishawn’ should turn up results, he’s a NYC EUC Rider and he’s pretty skilled. He gives a good benchmark for what an euc can do
Or perhaps unrealistic expectations and foreseeable mistakes trying to incorporate a 13s12p into a hummie deck was just a bad idea :thinking:
This is a small 1845, with external bms
Nyc has done it
2200, 24s6p NCR20700A 5000MAH 15A CELLS
Any idea what cells they use?
Wow perfect timing
5000mah 15a cell’s
Sanyo ncr21700a
Not the 3500mah 30a varient
15A…That’s why they need so many cells
Damn…Impressive
Any thoughts to a lighter, slimed down model with a battery backpack?
Obviously you bought them, And didn’t build them, but I could totally see someone doing something like that. I’m assuming it’s using a massive built in hub motor as well… lot cooler than I thought they where
Stock config is 1230wh 24s4p 18650ga
No one has gone faster than 43 @this config
I think you want that heavy weight as your low center of gravity
True, makes sence seeing as balance is key on one of these
Well the 2000w hub motor already does that, it weighs like 40lbs alone :joy:
Any issues with replacing blown tubes? Or are they an airless type?
There tubed, many put slime but I’ve got 3k miles no blow
100.8v max voltage
100v is just crazy to me, don’t most e-motos use a little less than that? Like 72-96v
