Oh the scarf is critical as well, I forgot about that.
Number one for cold weather riding is layers.
This includes a “dry layer” to stop ice and snow from melting into your clothes.
I typically use 2 layers under 10 degrees and 3-4 layers below 0 degrees.
Thermal leggings and a thermal shirt are a must.
No, Bosch. I have no idea how these types of clothing are called. All I know, on Amazon they are cheap AF.
Just dress like a snowboarder, their kit is built for crashing into snow.
You must be talking about °C because I wear 2 layers under 65°F (18°C) and 3-4 layers under 40°F (4.5°C)
At 20°F (-6.7°C) which is the lowest temperature I will ride in, I’m wearing like 8 layers
I ski a ton too. It’s different from riding though, I move a lot more.
…and can go over 60mph
Of course I’m talking about Celsius, it’s what most of the world uses.
I’ll ride down to -17ish but that’s my 5 layer zone.
Skiing isn’t the same as snowboarding. I didn’t say to weak ski tights and whatever lame shit skiiers wear.
In before the hipsters switch to °K
Only thing that’s Close the type is my base layer or is lair or “dry layer” I think you called it.
I wear 3L fabric outerwear, not sure how that compares.
2 boards > 1 board
8 boards > 2 boards
If you can count your boards you don’t have enough boards.
By dry layer I mean something like neoprene or anything waterproof, just anything to keep moisture from seeping in.
The rest of the layers are to prevent the moisture inside your body from freezing.
Outside moisture is cold, inside moisture is warm, don’t let the two systems mix.
Ice scraper mitt had the scraper snap off so I sewed up the seam and use it as a remote cover when it’s cooooold.
honestly I like foreign people in Germany because then they’re all like happy and grateful and stuff and I know them to be super chill.
But Idk how and this is not in my experience but are Germans systematic snitches? Like most likely to have some government report number on speed dial?
Yes and no.
They’re all just stupid cunts.
Hey now
Huh?
Why am I tagged here?
Seemed like a good candidate for a heated battery enclosure? Ill show myself to the door now.
Yeah in San Diego with my intense artic snow and blizzards lmao
