These are the calculators I’ve collected over the years.
3DServisas Esk8 Calculator:
One of the best IMO. Lots of good data.
Omni Esk8 Calculator:
https://calc.omniesk8.com/ GONE
Based off their offerings but you can put in your own values and it shows a ton of data, pretty great.
Ramm Boards Range + Speed Calculator:
Use our simple tool to calculate your estimated range and top speed. Simply select your model of cell from the list provided, enter your desired battery configuration, motor kv and a couple of other parameters and let the calculator do the rest. This...
Also based off their offerings but you can put in your own values. Aesthetic.
@mmaner Calculator:
https://mmaner.github.io/esk8calc/
Found it on GitHub one day. Great calculator dude.
DKwan’s Range Estimation Calculator:
https://dkwan.com/esk8-range/
Mostly for figuring out which prebuilt to buy.
Boundmotor Calculator:
Electric Skateboard Calculator
They aren’t paying their bills so it doesn’t work anymore.
MBoards Tool Hub:
DIY Electric Skateboard Parts - Build an Electric Skateboard
MBoards is your one stop shop for everything you need to build you r very own electric skateboard. Motors, batteries, ESCs, VESC, enclosures, and so much more.
A few useful esk8 calculators. Issues can be communicated on their discord server and are usually fixed within minutes.
Todd’s esk8 Calculator:
Basic. Old. May bring back memories for some.
@Shadowfax Force Calculator:
A Google doc that holds a ton of esk8 records, calculations and has pages for rankings and iron losses. Best one out there IMO.
Esk8.News Calculator:
esk8.news calculator
The one we all know and love.
If anyone has any more please add them. Not sure how to make this a wiki.
Russian. Battery pack Layout Calculator
For brick-style packs. Can do 3-7 sided packs and has circle packing tools. Found by @Steuka
Noice! The 3d servisas calculator doesn’t work for me. Am i missing something?
I could never get it to work either
Does the page open for you? There’s a lot of values on the 3DS one, try scrolling down. Each side of the page scrolls seperately.
@Shadowfax too
dimos15:
Yes it doesn’t work
Very descriptive, I can totally envision what you’re going through and what the problem is, this really helps me to help you.
Reads to me like the page opens but the calculator doesn’t work.
It works for me just fine ¯\(ツ) /¯
The Overview section is grayed out for me
Yes, that is where the calculated values appear.
You can input values in the other side.
dimos15
January 29, 2025, 5:00pm
12
Ok it works, you have to disable adblock
The 3ds one was always my favourite. I haven’t used the RAMM one for a long time, I liked that one but I didn’t like that it had the cell parameters preset and not customisable.
Not sure if this will work but here goes…
https://90aa6e26-dea3-4237-a725-4ec1bbf2fc2e-00-1kphxg6vfpo8q.worf.replit.dev/
Thanks to @Shadowfax for doing this first. I just figured this webapp might be convenient.
Edit: doesn’t work. Gotta learn how to deploy a webapp now.
I’ve been hoping someone would take the calcs and make a browser based version. Good on ya
