I’ve just picked up a used broke leafboard to try to repair. Got it really cheap so couldn’t say no. I’ve just been doing some testing and I’ve run out of ideas.
The board powers on, but no response from the motor. The remote pairs and if I press the acceleration the esc lights up.
I found that two of the phase wires had shorted together. Could that have blown the esc?
Battey is fine, motor is fine, can’t see any broken wires.
Can anyone suggest anything else to try?
I’m sure I will end up putting a vesc in but I want to try first.
Meassure resistance between the phases to check for shorts (whitout motor connected)
Meassure continuety for similiar resistance between each halfbirdge, look for visual damage.
Definitely appear to be a short between the phase wires. Also they are reading 9.5v with no throttle input. Can’t see any visible signs of damage. What do you think?
