It’s tough to explain without taking you through a bunch of graphs but “voltage sag” is the extra voltage drop that occurs inside the cell due to its “internal resistance” (IR).
This voltage drop, the voltage sag, is different and in addition to the drop in voltage that steadily happens as the cell is discharged. When current is pulled from the cell the cell’s IR causes the cell’s voltage to instantly drop, sag down. The higher the current level the more the voltage sags down.
This sag only happens when current is being drawn. As soon as the current stops the cell’s voltage pops back up.
When using a cell this sag causes the cell to reach your low voltage cutoff point sooner (since the cell is running at a lower voltage). If you run at a low current level there is only a little sag and your running time will not be shortened by much. If you run at high current levels (for the cells you are using) then your running time will be shorter. If you are running the cells very, very hard your running time could be very short.
You might have bumped into this voltage sag effect before. If you ever used a battery powered device with the battery almost empty and it worked at a low speed but immediately shut off when you tried a higher speed then you saw the effect of sag. The higher speed drew more current which caused more sag which caused the battery to instantly drop to its low voltage cutoff point.
Or maybe a power tool could be run with no problem when just holding it up and pressing the trigger but it stops immediately when you try to drive a big screw in.
Sounds a bit low? What do you feel it should be and why?
It depends on your preferences and how much riding time you are willing to give up. Sure, you could run your pack at 75A. But every time you draw that much current, even for a second, the pack’s voltage will sag way down and the ESC might throttle down because of that.
Less current can limit what the motor(s) can do but you don’t set current limits based on what you want to do. You set your limits based on what your pack can do.
Go ahead and experiment. Compare your riding time with low and high battery current limits. See where you want to balance performance with riding time.
All this theory stuff is fine to discuss but if you haven’t played with these tradeoffs before then it’s better to just go out and (safely) see how this all works.
