I don’t “think” that would work… the Caliber trucks you posted are RKP trucks I believe… you need a TKP baseplate…
What I found out that works very well is run DKP (stock eLofty) trucks up front, and take out the middle king pin piece on the rear and it all fits together! Rear then ends up something like a 35 degree truck, so you’re running essentially 50/35 split angle trucks!
Super turny/carvy up front, stable and not speed wobbly in the rear.
Took this video a long time ago when I realized my 3D printed hub broke(has been strengthened since). But what’s interesting is that you can hear the birds in the background. So damn silent!
first of all, tighten and locktite every nut/bolt/and screw you can find on the motor(s) mine came completly lose and none were locktight. one motor came apart at the can a couple of days ago that was 1km old.
I don’t think it’s an issue you can solve with replacement axle. The motor will unscrew the nut that holds it in over time. Your best bet is to remove the motor and shim the gaps between the square key and the hanger. Then loctite the nut in very well. But don’t over tighten the nut. I added nylon and rubber washer on both sides so hopefully the motor doesn’t back the nut out again.
also check the nylock actually contacts the threads on the axle… the replacement axle i received recently is manufactured incorrectly and the nylock is ineffective… locktite is your friend!
I was actually in talks with them until I confused euros and gbp
At 239 GBP, that’s around $300 not including shipping from overseas. That’s a fair price, especially over in EU but I’m located in the US.
I should be more specific and ask for shipping to US prices. I know there was a recent group buy for $267 shipping included and was hoping to see if I could either organize another GB or get a single unit.
