Thanks man!!!
is that 46mm depth at the ends the maximum, nominal depth, or minimum depth? Also, is that depth measured at the centerline, or the edges? And does it account for the thickness of the bracket or no?
New iteration of the Idea enclosure, the Idea DS, this time for huge battery lovers and loads of room for electronics
The enclosure can be purchased here
The Switchblade 40" Black Pinecone edition, flexible deck is here
This enclosure has been designed for the second iteration of the Switchblade from Landyachtz, called the Black Pinecone. The difference between this deck and the regular Switchblade Chief Night is that this deck is slightly flexible and features a W-shaped concave for a more comfortable ride. The enclosure had to be redesigned and molded to fit the new concave.
The enclosure can hold a 13S5P battery made of 18650 cells or a 13S4P battery made of 20700/21700 cells for high-output current discharges.
The enclosure is made of reinforced fiberglass for maximum durability and features a new air vent design on the surface that follows the angular shape of the Switchblade Black Pinecone, transforming a simple longboard deck into a high-speed electric sports vehicle.
You can order it from this link
Heya Alan, quick question.
Are your shipping fees fixed? I’m trying to place an order for an enclosure but the shipping cost is a whooping $78, is there an alternate shipping option that is hopefully more affordable?
Whee are yo located?
A new enclosure for the Lacroix Nazare has been released!
It seems many of you have been struggling with the Lacroix enclosure and the lack of support since the company went out of business. This tough and flexible enclosure is here to bring your Lacroix Nazare back to life!
You can order it from my website in this link:
does it have the same mount hole placement as the stock one?
Singapore.
Same as Gen 1 it appears. I have about 20 gen 1 decks if anyone needz
Looks great! Looks like a carbon copy fiberglass copy of the original stock enclosure.
Great work Alan!
What flex are they?
Yes, it has the same exact holes pattern
tempting…
@tuckjohn get in here and sell these naz deck enclosure combos. ![]()
This significantly more tempting than it should be. How many decks can a single person ride??
More than 10
I dare you to make 10 nothing fancy’s and sell 'em. ![]()
I mean….if there’re buyers…
