A long time has come by since the 2016 days and I feel very honored to be able to have collaborated with so many Vanguard Builds.
Throughout the years I had several requests for a bigger enclosure in order to fit bigger batteries but the enclosure never changed design, it was the same enclosure as day one but with small modifications, like a 12s version, a taller version for thicker cells, the updated version for 21700 cells and so on.
This is why I consider this enclosure to be so special, I feel this deck has been with me forever.
So I started to think of a design that will allow builders to fit not only bigger and thicker cells but to carry more cells inside an enclosure with a level of flexibility that could withstand the stress of such a flexible deck as the Loaded Vanguard, so I came up with this enclosure:
I pressent you the Vanguard MKII
The enclosure has room for a 18S4P or a 12S6P with room for an ESC and BMS, it will flex as much as the Vanguard deck and the center has more ground clearance it order to avoid bottoming.
