Hello builders:
As some of you know, I’ve been offering enclosures for quite some time now at www.eboardsperu.com. I always tried to select the best materials in order to withstand the vibrations and abuse enclosures are usually exposed on electric skateboards but, at the same time, keeping the visual design as priority number 1.
Now, I’m putting together some combos for popular enclosures with decks. At the moment I have only some combinations in stock, but I plan to have all of them sometime by December.
Brand new deck (depends on the deck)
Enclosure selected for the deck US$ 125
Rubber gasket US$ 20
Bolt Kit US$ 15
Labor to bolt the enclosure rubber gasket, nut insers amd bolts US$ 50
Through holes are my favorite because they will hold from the deck surface and not from the threads on the wood which my fatigue and loose due vibrations or heavy electronics. Besides que stainless steel ones are heavy duty, they won’t strip and will withstand against rusting for years.
Sorry I should have been more clear! I meant, which of those deck+enclosure?
And I’ve been meaning to ask, is it possible to get the enclosures without the decorative swoops (the abdominal muscles)?
Do you have any problems with screws seizing up? I have s/s screws and nuts for truck hardware, and I have to lubricate and go slow, or they gall, and I have to cut them off.
I love drop down decks like the Subsonic Century, LY Evo and LY Swichblade, those are the most stable decks in that particular order, the LY Switchblade is the most visually appealing one if mounted drop through, because looks like a racecar with big wheels.
Unfortuntately, I’ll have to make a new mold for that, if there is enough interest I can always make it. But it’s like asking a painter: hey I love your paiting but would you sell me the canvas only?
