E skate parts for sale
Olympia WA, USA
Up for sale are a few used parts
Everything worked the last time I used them
With the exception of the VESCS. Buyer pays shipping ($5-10)
First off is a steez remote with silicone protective sleeve and charge cable. Sorry no receiver the board was stolen. $20
SOLD Item 2, All of these VESCS for $60, they all have something wrong with them, but I believe two work with ppm just fine. The dual VESC has one working side.
Item 3, $140 a used Tampa infinity hanger with a dual belt drive setup. Included is two stainless steel truck clamps and two stainless steel motor mount plates. They are all 17-4 SS hardened to 45 HRC for a rock solid mount. There are two aluminum 10t pulleys and two steel 14t pulleys. There are a set of longer belts that can be used with the idler bearings, and a set of steel reinforced TPU shorter belts that can be adjusted with the motor plate. Two aluminum wheel pulleys that can hold superstar hubs, but are drilled for a 3 hole pattern and a 6 hole pattern as well. There is all included hardware and a RGB LED light bar as well (1/4-20 allthread rods required for mounting) Everything works fine but the idlers need 2x skateboard bearings, and the motor plates will hold a bearing in the center of the motor mount for decreased load on the motor bearing but only one is included.
Item 4, 2x skateboard belt drive with belts. $10
Item 5, $100 a Photon remote with receiver and spare faceplate. There is a dead receiver included as well.
I’ll take the hanger
The hanger alone is not for sale. Thank you
How did you manage to kill that much vesc, and keep buying the same ?!
When you realized they weren’t lasting why not try different one
Any of these DRV errors? I have some DRV chips and am local to you, westside oly.
need more for practice anyways so may want regardless.
I’ll take the ESCs if they’re still available. Sent PM. No worries if not.
These were from several different projects, and I bought them pretty much all at once to test the different brands selling them. These ones just had a few issues
if those are still for sale id like to buy them, looks like a good holiday project
VESCS SOLD. Thanks guys!
