dv6s Help Please
Just got my dv6s set up done vesc tool switch & filter bit run detection success …but it is Not ok sounds like motor detection ?? any ideas
Did you do a firmware update solely because VESC Tool claimed you needed to?
I don’t know a lot. But I do know I had a similar result after going through setup using a Mac.
Fucked with it forever.
Then got an old windows pc - perfect first time.
MakerX hates Mac I believe…
But did you update the firmware? Because if you did, you need to flash bootloader first otherwise everything is wonky
Definitely do this and then flash the fw again.
Also, make sure your sensors are plugged into the correct sides. I’ve had similar fuckery before when the sensors were plugged in to the opposite sides of the vesc.
Ok makerx got back asked for foc wizard results so set him video of results will see what he says :slight_smile:
No vesc tool update
No firmware updates done yet as came with right one
Vesc tool run on a PC
Double checked sensors wires in right side even resoldered my bullets on motors checked power wires
Thanks for all the help/ideas :slight_smile:
Huge Thank you / Shout out to @YUTW123 for 2 hrs of help today to problem solve my issues with my dv6s , Super grateful for your time and help. Can’t wait for the rain to stop to get out there :slight_smile:
