I have the dual sk3 setup on my board but I only have 12mm belts so that’s probably why you’re having issues.
That looks like about the spacing I’ve got ya
This setup will fit the legendary Boardnamics 220mm hangers but I am out of stock
First testing of them from summer 2019. What a much better summer it was…
Whens the restock?
whens the restock?
5984 if I recall
Lol what the fuck?
these appear in stock, but not 220mm
Probably not for a bit. I’d you want just one I have a used one in good condition
Pm’ed
Lol. There is no way those will fit in there
You need to have faith in humanity my little grasshopper
Let’s call the guy… @janux-esk8, bring your butt over hereeeee !!!
Voila!!
It…can …be…possible. You … just… need …to… believe Torqueboards 218 + SK3 6374s + Janux mounts
Yes, yes, go ahead; you can say it… (attaa boy…click that button)… ‘Best Answer’
I’m still so confused how those are fitting. Is it the mounts? I have a pair of TB mounts I can try that look similar to those but, but I just don’t see how it would make a difference. I have the motors staggered right now to get by until I can figure this out.
I have some 12mm belts and pulleys I’m trying tomorrow.
Is possible to fit Turnigy SK3 6374 motors with @Janux-esk8 custom mounts on Torqueboards 218 trucks. Talk to the guy.
@Janux-esk8 I need to learn the ways of the Jedi. How does this fit?
These are the custom mounts you need to order with him to produce that magic…
Unfortunately those wouldn’t work. I regularly swap between my 97’s, 120’s, and AT. Need longer mounts.
Yeah, precisely. You can order the same ones but longer, to fit your specifications. He accepts custom jobs on top of his standard mounts.
It may also depend on the wheels and if they are offset or centerset. I find that with kegels I can get more space than abecs for example.
