What do people use when mounting trucks drop through on the bottom of the board in order to not be cranking bolts down on the wood? I have seen only riptide (backing plate)
Does anyone have any for sale ? I am using caliber 2 trucks
Just get some washers? You don’t need it hella tight, I use a shock pad to even the tension
Moon’s “I beam” style dealies.
G-Bomb Infinity Plates here, they’re pretty thin so not much difference from using washers.
Shredlight brackets also make great drop through plates. Depending on the drive system you can use them front and back. not so much with direct drives though.
I used these 2mm drop-through rubber risers, above and below the Drop-Through openning…
But you can use them just below. Remember, on a drop-through installation truck mounting plate washers and nuts are the ones holding all the weight of deck and rider, not the truck mounting plate.
I think I am going to try the shred light mounts since I would like to get the lights eventually
Thanks
@pixelsilva there is no way to buy anything from that site, it appears to be informational only.
Oh, then try Amazon. I got those from them.
