hilarious. I’m using 6374 190KVs at 60-70 motor amps and usually 35-40 battery amps. yeah they get warm, but by the time they’re too hot to touch the battery is drained.
thank you.
how noticeable is this on the street though? Or is this one of those things where you would get better returns simply by eating less and maybe walking somewhere now and then? aka losing weight.
This weekend I promise to bench test my 190kv 6355, 190kv 6374, 170kv 6355, and 170kv 6374 Maytech motors and submit them to the motor dyno database. Then we can solve these mysteries once and forall for the most popular esk8 motor sizes.
An easy fix would be better cooling. The problem with higher voltage ESCs, is the higher RDSon of the mosfets - so unless the ESC has more mosfets to distribute the current draw, the power actually doesn’t really increase, or even if it does, not by the amount you expected it to! Remember…
The thing with both of these setups is, performance wise, they will be the same. Each set of motors is putting out the same mechanical power either way for any set of riding conditions, whether under acceleration or constant speed. But the 18s set of motors with less motor current will have lower I^2R losses for any identical performance condition. When you add up the I^2R losses and the mechanical output, it approximates the battery wattage. So essentially with the 18S option here, the same mechanical power is coming out of the motor, but less electrical power is going into the motor, because less I^2R losses are coming out of the motor in the form of heat.
So essentially these 2 setups give the same performance, but not the same electrical wattage for identical performance. The 18S draws less wattage from the battery for identical performance.
But while we’re on the subject, there’s no good reason to lower the motor current limit on the 18S option, so essentially, lowering the motor current limit is pointless, and when you don’t do that, the 18S option gives you 50% more torque if you gear for the same top speed.
Also I think you meant gear ratio is 50% higher on the 18S (not the 12S) for same top speed.
I don’t think anyone is running 190kv at 18s and spinning up the full RPM allowed. Usually people are going down in the 120-140kv range. Lower KV motors handle less amps.
Resistance in the motor goes up by a ratio of 18/12 = 3/2 if we adjust the Kv. (same thing applies to the battery)
Current goes down by a ratio of 12/18 = 2/3
(2/3) ^ 2 * 3/2 = 2/3.
Actually, if the Kv is the same. The resistance stays the same so in reality it’s 4/9 if you just change the gearing.
The problem is you need a multistage reduction at that point.
Bingo. That is going to introduce it’s own inefficiencies.
I have gone from 6s to 10s to 12s. Zero difference when setup the same way. Only reason I run 12s is that my board is a travel lipo setup and 12 goes very nicely into 2/3/4/6.
Did you see the beautiful graphs @fessyfoo shared? They are excellent at highlighting how any extra speed is with less torque at the high end, or any extra torque on the low end ends sooner than usual.
And I will argue that you can achieve the same effects remaining on 12s by going higher kv, or higher kv with a larger gear ratio, as long as you can still increase motor current in your ESC.
This is where your misunderstanding is. You can still get 30a motor amps through both motors at the same time that you are not exceeding 20a battery amps per motor (40a battery combined.)
But on a 12s setup, you will always have 50% more amps available. I don’t see what your point is. Its like saying you are faster than a ferrari as long as no one is driving the ferrari. LOL
I think the broader point is that saying 18s > 12s isn’t really true. We can talk about a little give and take here and there but for esk8 atleast, 10s,12s,18s doesn’t really matter as long as you know what you are doing.
