I was thinking about putting an external control panel using the switches pictured below, and I was wondering if I could use the switches to power on my SC 60d+. Obviously I would power it with the 5v pin, but would I need 1 or 2 output pins from the switch (I can choose 2 or 3 pin), and if 1, which pin on the SC would I have to connect to?
Flick switches like that are usually a bad idea in esk8 because of their ability to be knocked into the off position quite easily. Buttons aren’t as easily switched.
The stormcore switch is momentary, so a rocker switch like this isn’t gonna work without some other fuckery.
Something like this would probably work if you really want that style of switch
TWTADE 3 Pcs Momentary Heavy Duty Rocker Toggle Switch 6 Pin 3 Position (ON)-Off-(ON) DPDT 16A 250VAC Spade Terminal Metal Bat Switch with Waterproof Boat Cap and 6.3mm Terminal Wires TEN-223MZX-B223 https://a.co/d/gzi8oud
