Hi!
I want to build two boards. One for carving on the streets with urethane wheels and directdrive system and a mountainboard. I want to start with the mountainboard since I already have an electric street board but now I got a good price for a 12s4p battery that would eventually go into the diy street board. Is the 12s4p too small to use temporarly on the mountainboard? How do you think it will voltage sag? Around 15 miles range without much sag would be ok for me.
The plan is to upgrade to a way nicer battery eventually… With very high quality cells so I can put not much cells and have very nice power.
The specs of the mountainboard:
Haero Bro deck
90kv Maytech 6374 motors
Gearbox ratio 1:30, 1:33 or 1:26 (I will use low kv motor so gearbox ratio is low so more quiet)
Bkb zenith or Spintend Ubox vesc if I decide to go 14s or 16s
I will buy 8 inches and 9 inches tires
I am 200 lbs
I would like this board to go around max 40kmph but have great torque.
I have not chose right now if I will go 12s, 14s or 16s for the final battery. Maybe 12s is enough since I do not want to go faster then 40kmph…
Please share your thoughts about that small battery and about going 12s 14s or 16s for my needs.
I can get it to sag if i want to but usually it’s not a concern the way i ride… If you go ham on hills it sags but still gets you to the destination. Short term - definitely works. Long term i would go with a higher P count.
Your mileage may vary. Same goes for my streetboard, i can get max 16.7miles out of a 2 year old 6.4Ah battery or kill it within 5miles.
15 miles on 4p is probably doable as Zach said but not as fun. You definitely feels the sag at 30-34v
Are there even 36T pulleys for MTB hubs? That seems really small, and you’re probably going to need a custom pulley to reach the bolt holes. Also the Wh/km seems a little optimistic for pneumatics.
