Add fuse between charge port and CH- and the rest look good. Consider not running sensor wires, or only running the GND (black) and TMP (white) sensor wires.
Could you clarify why you want to fuse the negative lead and not the positive?
I always do it the other way, rather have the positive line cut then ground.
Edit: missed your last comment, still would like a better explanation tho xD Cutting positive from the outside world still makes more sense to me
Usually you have a common ground in electronic circuits. You don’t want do disconnect the common ground so you fuse the positive wire.
With our BMS however all positive wires are connected and the negative wires are switched by the bms. @b264 continues this philosophy and fuses negative so all positive wires can stay connected.
In reality it does not really matter as long as there is a fuse I guess.
I mean, I’ve designed over 100 different kinds of PCBs for a variety of applications, automotive, medtech even BMS’s. I’ve asked the same question to more senior designers and they just scratch their head as well.
I mean, sure, In general It doesn’t matter as long as w/e caused the fuse to blow gets disconnected. But in the scenario that ground or supply is hanging out externally, I’d much rather have supply cut off since it could short against something else with lower potential. A good example is f.e metal housings or enclosures that might have PE.
There are also sevral standards pointing out that the device should have fuse on positive end
But I keep getting proven otherwise, especially with stuff from china. Boggles my mind.
Depends how fast the fuse blows, usually u can draw 10A out of a 10A fuse all day(unless its a fast blow fuse). All manufactureres seem to define when a fuse blows differently, so its abit of a mess.
I had a return at work where someone drew 800A out from our 450A fuse for a few secs, the system overheated before the fuse could blow
I think it comes down to the differences between nFETs and pFETs really.
It’s really just longstanding convention and tradition that dictates “ground” is the electron-emitting side. This could have easily have been the other way around since way back in the day.
I agree that it’s always better to stick with convention if you can. But since china BMSs are essentially ALL wired with common positives, then I just adapt and wire all my china-BMS-containing devices that way as well.
The reason I think you normally fuse positive is because sensors and data signals usually use the common ground. It’s better to cut positive voltage to not separate ground somewhere to not mess with the data of other circuits that might still run on another positive voltage.
