higher kv motors can handle more amps before saturating so if you gear down the higher kv motors to the same speed and you’ll have more torque. @Shadowfax has The Ultimate Esk8 Calculator where you can put in all the info and see actual values.
if you had a board on 18s and a board on 12s, if they’re both running the same everything, only difference is the battery, the 18s board will be faster
