I have an ESC and aome pins on the top panel needs some repair. However, to unsolder the broken parts i need to access to the bottom side. On the other hand, the bottom side has another panel / pcb connected with 24+ pin connectors…at least it looks like those are the only connectors on the two sides. I cut off the white glueish/ siliconish material but still not able to separate the two sides. Can i just use force or something is there which i miss?
I just twisted a large flathead at 4 corners by removed screws, and it lifted off without protest. Nothing but the screws, multi pin connectors and the white sealant on connectors held mine together.
