Is there a way to disable the ABS Overcurrent on a VESC 6?
Change Fault Stop Time to 0ms or 1ms
I never said it was a good idea
Much harder to disable the ESC from blowing up the DRV from whatever underlying cause.
If you’re having the issue while riding, make sure that slow abs current limit is true
Been having issue with it cogging when I go to max throttle from rest, it’s been tripping the abs code, but can’t increase the current in the settings get the truncated error when i do.
anytime I’d cog (around 35% duty cycle) it would trip the abs fault
I’d double check phase wires and solder joints. Cold solder joints or bad connections can cause an ABS overcurrent. Might be also a good thing to take apart your motors and inspect them if the wiring check came out without any issues.
Last option would be to load the hw no limit fw which allows you to rise up the ABS limit. I would set it to 2x motor max current, but not more than 250A and see if that’s going to help.
Bruh, it wasn’t asked how to fix the problem, it was asked how to disable the ABS Overcurrent
Ahh, yes
