You should probably read through this thread a bit. No one really knows weather or not they’re the same as the og elofty’s, there are some clear difference’s between the bound first drives and lofty’s like the set screws on the cans. These new ones are a bit different, I’m wondering if they changed anything with the axle’s or else wise on the new version.
I’d also probably consider TB110’s for a little more ground clearance than the 100mm boas.
Hey! I actually purchase the V1 of these motors. They literally updated a week after I ordered mine. I'm not mad though, because the v2s are a whopping 6mm larger due to the 3mm thick additional heatsinks.( which would be a plus if you plan on running no less than 107mm wheels)
I originally got 100mm MBS all terrains, but I was clipping my motors on most things (I like to go up curb ramps and occasional dirt trails) so I switched to torque boards 110mm arctic blue 74a and OMG I will never go back, most comfortable ride... sorry, I digress.
The motors perform great! And I’m only 10s!! Getting a top speed of 28mph on flat ground with the 110s on 10s… and 11 miles with hills
- I live along the coast in Monterey Ca. I weigh 220 lbs.... ah man I'm rambling... what's more. I dont like double king pins, so me being an experimental at heart I attempted to run them single kingpin by removing the middle peice, and it worked!!! So I can enjoy the benefits of long/wide wheels base, with the stability of single kingpin and because the trucks are so wide you dont lose carve-ability , I'm comparing to my reverse King pins 50° . Ill try and post pics... bottom line is, these are worth the price at 350$, especially compared to others like torqueboards DD for 650$!!! For motors and rear hanger only.![20200427_084014|666x500](upload://pTNgmzbzct9Hy6oFsWjhnKlsZ8t.jpeg)
Those are the hubs you could convert into DD isn’t it?
Now that would be your best option. Maybe you could ask @rey8801 if he still got a conversion kit (I don’t think so but worth a try)
I have gen 2 lofty and current gen Bound both apparently 58kv the Bound DD struggle with anything more than 120mm, also not great at hills even with evolve 97mm.
