I already tried this: https://electric-skateboard.builders/t/diy-6s-to-12s-bms-with-can-diebiems/2639/415
I get no response in the terminal nor the console when I type bootloader_jump manually in. @JTAG
Solved it, I had to use the tool version 0.3 instead of 0.27 to be able to do the bootloader_jump manually…
What’s new in 0.3? When did that update was released?
It is just released to make the switch from the old version 3.38 or something to 0.3 and then you can use the normal 0.27 again.
