Hey all,
I am wondering if anyone has a definitive guide for programming the Stormcore 60D+?
I have watched the tutorials by mBoards and some other guides like the video from Pavel Garmas. They guides are mostly good, but they always leave a few questions unanswered.
For example, The stormcore 60D+ has only 1 USB port. However, all the tutorials I have found imply that there are 2 USB ports, and instruct you to disconnect your USB cable from USB port 1 after updating the firmware on the first side, and then instruct you to attach the USB cable to USB port 2 to update the other side of the VESC.
The issue here is that, as mentioned, there is only 1 USB port on the stormcore 60D+, so I’m just not sure how I would go about that.
The other concern I have relates to setting current limits, which is vital to program correctly. I am running a dual motor setup, but I do not know what number to plug in to the VESC tool in relation to my setup.
I want both motors to get 25A each, which would make the total current going to both motors 50A.
However, I do not know if I should plug in 25A or 50A. See the attached picture so that what I am asking makes more sense.
please ignore the values already on the screenshot, as I have not connected everything together yet.
