Since winter is coming i wanted to add some LED’s on my skateboard so I bought a dc/dc converter LM2596 problem is it warms up a lot and shuts off because of safety reason.
Would appreciate it if someone can recommend a reliable dc dc converter that works nicely and warm while outputting 2A max. (Input voltage is 42V max)
That’s a step-up (boost) converter though.
That 5A rating is…umm…optimistic IMO. “Max” is typically not a true continuous rating, just a short-term capability.
The Delta board’s 4.2A current rating is based on using a 300LFM fan. How hot did it get (what current levels?) for you in an enclosure? Did you heat shrink it?
For the CUI converter, did you use the recommended input/output caps? Or was it stable without them?
