Firmware v4.08
Most important updates:
- ENNOID BMS support
- cell voltages display for up to 24S
- range ramp up (range temporarily projected from lifetime data after session reset)
- demo below
- lifetime max speed can be reset
CHANGELOG entry:
- battery capacity settings: step changed from 1 mAh to 50 mAh
- session mAh in/out changed to Ah and values above 9999 mAh can now be displayed
- fix: odometer not saved upon stopping
- fix: fixes/improvements to the landscape mode view
- fix: updating config from Metr CAN with empty wifi settings
- various other minor fixes
Range ramp up demo (if you haven’t seen it yet):
I’ve been holding the v4.08 in the RC state for an embarrassingly long time. The main reason is that I wanted to test the ENNOID BMS support. I received a sample BMS unit from Kevin to use for testing but I haven’t been able to get the communication working. After double-checking I’m not doing anything wrong with Kevin we concluded the CAN circuitry must be faulty on this particular unit. So I shipped it back and now I’m waiting for another one.
Unfortunately the ENNOID support hasn’t received the testing that would be appropriate for a stable release. There are probably a few loose ends that will need addressing later. I don’t want to be holding this release back in RC anymore though so it’s coming out as is.
