Anyone know where to get 8mm bore d-shaped motor pulleys in 16t or higher that fits haggy’s motors? 15mm wide also!
(this but in higher teeth counts
Thanks in advance!
Thanks in advance!
I think @dickyho has d shaft pulleys.
Regular pulleys work on the motors just screw the grub into the flat spot
This is true too. I have a board with the D.
I like having pulleys that match. Its a nice tight fit.
Tight fit😏
Just spit on it and tap it inn.
I like what’s happening here…
uhhhhhhhhh…
just messaged
Hilarious stuff right here
And then this happends
Flipsky has D type as well.
Seems like they only sell 15t
Ahh, good catch.
Bump. Did you ever find some?
yep, linked above there from dickyho
I have the Dickyho ones with keyway, I need a 16T with D shape bore out of steel.
those dickyho linked are d bored, but alu and doesn’t look like there’s 16t tho. you can try asking him, I picked up 18t myself.
