I bought a cheap 38" (second hand) switchblade but nose and tail are a bit damaged.
Do you think it would be ok to cut the part between the red lines to turn it into a fork shaped nose/tail (dunno how it’s called)
I like this style
When you say direct drives. You mean like torque boards direct drives? Because I’m pretty sure these will foul on the deck with drop through. Or am I miss reading?
Elofty, if you keep it in double king-ping mode, should be fine I think. Been contemplating going with that exact setup on mine, I think it will be a perfect combo!
I run my eLofty in a drop-thru configuration in the DKP front truck, but I run my rear truck without the middle piece of the DKP truck, so it’s like a TKP?, and mount it under the board with about 12mm risers, so I get a split angle setup, (50-35) very stable, but easy carving and no wheel bite or drive fouling the deck.
