Epic! I haven’t seen that. Thanks!
Sounds good. I’ll invite you into the project.
Will definitely be checking that out. Out of curiosity, mind if I hop on that fusion file aswell? Would love to see the workflow of someone more experienced than me
Here are some examples of different results generated from different loading conditions.
1st, the standard hanger for reference
And here are some of the generative outcomes
Sure, no problem. PM me your email address. Would be great to get some discussion going on the loading conditions, and get you guys to critique my assumptions.
Great point! I mentioned an assymetric loading due to the torque above, but you’re absolutely correct, it’s not actually an additional torque on that side, but instead a force from the belt tension.
with a belt you’ll get much less torque but the motor mount itself still acts as a lever, applying some torque to the truck, though i haven’t calculated how much
Hmm… ok, that makes sense. I’ll go back and look at what I did there. I can’t actually remember how I loaded that flange.
That last one looks pretty visually appealing. Have you considered mirroring the motor mount for 2 motors? Most of us on here find one motor to be annoying to ride with a single motor because of torque steer, loss of traction, weak power, etc lol
I have to wonder how much that would change the generation too, having uneven loading conditions would obviously make it run differently
Wouldn’t the force of hitting a bump with a heavy motor attached to a long mount be way more than the torque could ever be?
that depends how much of the bump the tire absorbs but I only compared the hub motor torque vs the normal force of standing on the board with no bumps
That’s instantaneous torque though, not persistent. It would be considered an impact load and depending on the material I would magine that would make a difference in the actual perceived effect on the truck
It is pretty hard to track all of the miscellaneous loads though, I would personally probably tend to just throw a bigger fudge factor on to account for impacts
another big issue I see is it doesn’t appear you’re using a through axle so if the material is aluminum, the truck doesn’t have an endurance limit, so over time, vibrations will lead to failure
Yeah this is true, a lot of the cast trucks use a through axle, but comparatively the machined material should be stronger than cast because of metal grain.
You’re still right about vibrations though. The type of aluminum would make a difference a little bit but ultimatey could fail. Vibrations could run the cycles up pretty quickly too
We all know what happened with the aluminum fLExl trucks lol
I didn’t think of mirroring it, but I’m about to start a mountain board project, so I was planning on doing a new setup with loads on both sides. The mirror option makes much more sense. Thanks for pointing out what should have been obvious… I’ve experienced the frustration of a single motor on my road board, spinning the wheel on heelside turns, so I totally get what you’re saying.
wouldn’t want this to happen:
Yeah most of the time I get zero motor spin on my board even on sharp turns because the torque of the other wheel forces the truck down and the other motor compensates
I love these comments. I should have got this discussion going before I started working on this design!
Absolutely. I’m totally expecting a fatigue failure at some point, and a bit scared of it to be honest.
