Cross Fox - Sportster | BN220 | Bergmeister | 12s3p P42A | Unity
Goddam she’s lookin’ sexy today :heart_eyes: We got the Paris V2 50/43 baseplates and the Riptide Caliber II cast pivot cups in, and it’s so pretty now…I have it set where at the proper bushing compression for my rising it I have just enough clearance to safely drop mount, and with the 43 degree rear it’s got just enough clearance to have the motor mounts tilted up. Overall quite pleased with this, it’s gonna be wonderful.
The new ride height feels a lot nicer to me and the added 1" on the wheel base should combine to make it a much more stable ride (not that I need it, I’ll never go above 35mph), I think it will ride like a dream.
I can actually ride this upside down, I have about 1/4" of ground clearance at the baseplate and since it’s a double drop the flex doesn’t bottom out…not useful but it’s a proper ultraboard now.
Only caveat is the hangers sit farther in the cups than they are supposed to, it’s off by 2mm so at some point I may have to insert something between the pivot cup and baseplate so it sits farther out, currently the bushings take the load.
Current parts
ASSEMBLED
Deck: Bustin Sportster
Baseplates: Paris V2 (50 deg front and 43 degree rear)
Pivot cups: Riptide 96a WFB Caliber II cast
Hangers: Boardnamics precision 220mm
Axles: Bolt Depot 60mm shoulder bolt
Bushings: Riptide 90a KranK barrels
Motor mounts: Boardnamics precision idler
Motors: TorqueBoards 6374 190kv
Motor pulleys: TorqueBoards 15T
Belts: V Belt Supply 385mm HTD5M 15mm
Wheel pulleys: Custom printed ABS 60T bolt-on
Hubs: Haggy Bergsmeister (orange)
Tires: Haggy Bergsmeister
Bearings: Zealous classic
OWNED
Enclosure: BigBen 9 Two 5 (milk white)
ESC: Enertion FocBox Unity
Bluetooth: METR Unity
Remote: FlipSky VX1
Battery: Molicel P42A 12s3p (flex)
BMS: LTT smart 12s 20A
Power button: Meepo V3 momentary
Charge port: 5.5 * 2.5 barrel jack
