I have a a few questions I’ve been meaning to ask the community. I can only think of two right now but wil add on as needed.
Firstly, whenever i turn on my mini remote, my board jumps forward/jolts a bit. This has happened with the two different ESCs i have used on this board thus far. I have however been using the same motors and battery setup for both ESCs.
Secondly, where can I get heatshrink that is nice and flexible after shrinking down? I used some regular stuff o n some hall sensor wires and its very inflexible.
I’ve never used anything that’s very flexible. Probably the same as what you’re experiencing. It helps if you have the bend you’re looking for in the wire/tubing before you apply heat, if that makes sense…
