I want to route my phase wires into my deck from my central top box through to the trucks, but I am concerned about routing the full depth of the 12awg wire… especially because I would need to run 6 phase wires, 2 x 6 core sensor wires and possibly more for lights and accessories…
The sensor and accessory wires are no big deal as I can remove the outer sleeve an run the individual wires next to each other.
I am considering using copper braid as the phase wires that run through the deck and epoxying it in @longhairedboy style.
I know that if braided wire is soldered too much then it can become brittle and prone to snap… does the same apply if it is epoxied into the board?
I think boosted used braid or some similar wire on the V1 and maybe V2, never heard of them breaking, but they weren’t epoxied, just held in place by the grip tape
Terrible pic, but it’s one of the better ones I have
FWIW Boosted doesnt epoxy them to the deck, but instead uses some kind of soft silicone. It was moving all over the place when I was trying to resolder my connectors. Really annoying to work with.
Interesting idea! There is only one way to find out if it’ll work…
I imagine if you set the braid in epoxy it wouldn’t be as brittle as tinned braid. Epoxy is pretty flexible compared to solder. I would worry more about the epoxy plug popping out when the board flexes, but folks have been using epoxy in this way for years without issue
I dont think epoxy will make jt brittle like solder since it isnt wicking it in to the braid. I dont see why this wont work. What are you planning to do for sheilding? Just epoxy? Or maybe heat shrink?
Might still be good for other folks who see this thread though. See if he answers the call because thats one of the rare occasions I didn’t bookmark a post from Brian.
