So all that you just said makes sense. However, the PC/ABS wheels are cracking and crumbling in as little as 2 months. Normal Nylon + GF cores don’t do that.
You say the same thing might happen to Nylon+GF cores if they were subjected to the same loads as the I-wonder cores. If that’s true then there is not much hope.
You have manufacturing experience. I don’t. But I do know that there is a huge difference between plastics with and without GF. I think its worth a try.
I’d be interested to see the factory smash test performed on a conventional Nylon GF core.
What they really need is stress test for plastic fatigue. The examples that cracked were crumbling with fatigue.
I’m curious if you cut the core out of a traditional PU wheel, could the Iwonder tire be bonded to it? I would think that the tire is injected molded around a completed core. Correct?
Would it be possible to Outsource the manufacture of the cores to a third party that already manufactures Nylon/GF cores. Would it be possible to use the second half of the process to bond the Iwonder tires to Nylon/GF core samples?
It would be a way to produce some prototypes for stress testing. Heavy rider, cold weather stress testing.
