There is a list of all the parts with links to buy them. For me the pcb ended up being around half the cost, but I ordered a lot from amazon.
Print time depends on your printer/nozzle/settings. Its really up to you how fast you want to print it.
* 60mm x 60mm x 1mm non conductive [Thermal pad](images/thermalPad.jpeg)
Should these not be 0.5mm thick pads?
UPDATE: Ah i just read the parts list on github. I just remembered that shaman used 0.5mm on the beta units.
Yup, I have the pcbs on the way form JLC.
In testing,what sort of amperage values are we looking at before heat starts becoming a problem? Woud love to see some logs
@NuRxG What are the limits in firmware set to?
Sounds weird to me that 100A spikes throw an error. But what do I know… I don’t have CFOC2s at hand yet
someone is having a good time
Along those lines, I currently have three VESC’s in use. Two on my mountain board (6S) and one on my two-wheeled board (10S). These are all 4.12 hardware, and I’m pretty sure none of them have any heat sinks. How important is it for me to use heat sinks on the cheap FOCer 2?
@ziploc Depends if you want to put more current through them? I would guess if you don’t increase the load they should perform about the same. Adding a heatsink to them is so easy tho. You can use just an aluminum plate and few screws.
Yeah - I found some very cheap heat-sinks on ebay that will do nicely. I was mostly curious. Thanks.
Will order 5 or more PCBs and Parts in a few days.
I can order and assemble a few extra units if anyone from Europe is interested?
I would be interested in 2 units, I want to assemble them myself but I am not sure if I can assemble them with just a decent soldering iron?
Low-Cost(around $120 for 5 boards and components)
I just placed my JLCPCB/LCSC order. It ran a bit over $180 for 5 boards with shipping. This doesn’t include things like the heat sink. I’m not complaining, but am curious to know whether I did anything wrong. Is that what others are finding?
Sounds right. The shipping is about like ~$50 total for pcb and components. I wish JLC could make it one shipment, but they are two seperate orders.
@shaman Also maybe the BOM cost has increased because of corona?
If you get most of the components mounted by jlcpcb like it was intended it should be pretty easy to assemble by yourself.
