The lights also act as a mine canary — if they shut down while you are riding, then you have a serious battery problem and need to pull over and shutdown immediately. But this is without cutting your brakes or shutting down your drivetrain.
Anyone every measured the actual Amps they pull out of these? Because if the data pins don’t get the correct voltage depending on the device it will fall back to 0,5A charging. I’m looking to charge at 1.5 to 2.1A
OK, let me see if I understand. I connect the lights to the bms discharge, and this can help me drain the load, but in turn do I connect the battery with a switch so that I can turn them on when I need it?
#Aliexpress AU $5.75 22%OFF | DC 7V-60V to 5V 5A 4 Four USB Step Down Power Supply Module DC 9V 12V 24V 36V to 5V 5A High Power Buck Converter Board For Car
I use these on every build they are bullet proof, 12s and outputs 4 amp enough for 288 RGB LEDs, and I break out a water proof USB to the side of the enclosure. Using a USB male to male cable. #Aliexpress AU $3.48 20%OFF | USB Female Socket Plug Panel Mount Adapter Waterproof Connector IPL7 With Cap
