Carbon GTO | 10S4P | TB110 78A | dual FOCBOX 1.6 | dual enertion 6355 | Boardnamics 220 | Carbon GT deck [serious]
Mainly just namespace pollution so Evolve didn’t use the Carbon GTO name :rofl:
The stock racestars from evolve but sensorless
That’s your problem then; change the motors. I don’t even know if those can do 60A. I think around 46 or 47A is where mine are set on the Magnum Seed.
Put some 6355 motors on there and it will be a lot better.
I would but getting 63mm motors on these mounts doesn’t seem possible. Also would the performance actually even get any better considering the 10s4p 35E pack being limited to 32A (16A per side)?
I’m gonna set it to 45A per motor and see if I can at least fill the throttle curve in a bit, 2nd half of the throttle doesn’t seem to do anything at 60A motor (it maintains speed but doesn’t add any power)
Buy mounts
Yes; a lot better. Motor amps are not battery amps.
Will take too long and can’t afford to spend more on this one. Can I print something to make it work?
What about drilling holes in the mount? Ive pondered that when trying not to buy 63mm mounts for my evolve shit
I’d only do this if I knew I could make it work well. As it stands I feel it’s better to cope with the weak racestar motors and recommend motors and mounts as a future upgrade. I feel like the main rider of this board will want to stick with RKP so there’s a few evolve mounts I could point them to.
