Hello there first time making a post so bare with me. Anyways I’ve been having trouble with pulley wobble on my drive wheel. I’ve tried using a different wheel (same set just used the front wheel) and screwed the bolts in several different patterns. The wheels I use is a 83mm Abec wheels and the pulley both made by torque boards. Any info would be very helpful
A lot of precision on the initial placement, and tightening the bolts down slowly in a star pattern is required to get a centered placement on bolt-on pulleys.
It’s a real PITA.
That’s why people recommend push-fit pulleys which have their own bearing to align themselves on the hanger axle. It’s 10$ more or so, but 100% worth it to avoid the troubles.
looking back i shoulda just went with that path the first.time . thank you
This is your problem.
Use a pulley with inserts instead of bolts.
