I need help. This board was the biggest waste of money I’ve ever got myself into.
Ugh
I sanded down the area but any tips/tricks would be dopppppeeeee.
Ugh
You’ll probably have to Dremel out the area to make it a bit wider. The sandpaper probably isn’t enough. This is a very common issue with these.
Pictures?!
I’m confused, the sixshooters splits into two sides when you take out the six bolts. Shouldn’t new tube have new valve stems?
Yup, and the razor sharp edges and bad sizing slice the new stems.
ohhhh. Definitely dremel to round that out, It would take a lot of sand paper
A file might work too if you don’t have a dremel.
After dremeling out the valve stem area you can wrap some electrical tape around the stem to help
