Hello!
I have recently come into possession of a Luna X1 ebike battery. I took the entire thing apart down to the cells with wires coming off. I haven’t clipped off the existing bms and other circuitry connected to it.
My ideal would be to replace this existing circuitry with a different bms, remove the extra wiring, repackage the battery, and use it in an esk8.
This Luna battery is apparently a 48V battery with “premium GA cells”. I’m not exactly sure what GA cell means. I also can’t find discharge info on these cells. My biggest question is: is it possible/reasonable to disconnect the existing bms and replace it with an esk8 bms and then hook it to an esc?
Some other questions are: What amount of testing should I do before that point? Should I test each cell block individually? How difficult would it be to test this? What is the strange cell layout (seems to be 6 series of 8 cells in parallel plus a random 4 cell parallel)? What extra materials would I need to finish this battery?
Any help/advice is greatly appreciated!
