The flipsky video, with happy tune and chinese words, is useless.
Is anyone capable of giving simple instructions? My unit will be here in days. There seems to be ONLY one guide I can find. The stupid Flipsky happy tune one.
We have every possible type of youtube instruction video, but esk8 is sparse.
Also, anyone have a schematic of how to REWIRE for ppm and uart?
You can use them both to get the best of both worlds.
I haven’t done this personally because uart has worked really well for me especially after we got the deadband reduced on our stock.
If you ordered a new remote then it should already have the latest firmware on it. So no need to worry about updating it.
Also their wiring diagrams leave out the factv that in either mode you need to to connect bat+ (a separate wire from the connector) To the battery. Their diagrams make it appear unneeded when using UART mode, but it is actually needed if you want the remote to display the battery’s charge level.
I bought a new flipsky 6.7 dual to replace my unreplaceable 6.6 dual. And the vx2 worked for a bit, then, caused stutters in throttle only. Then nothing. And so, I tried everything, to wake up the potentiometer. Couldnt get it to register no matter what I did. Yet it registered the battery. etc. And so, I like having the ppm and uart function, just in case my uart circuit is somehow screwed.
Thus, being able to control throttle, thru ppm, is a workaround.
