I know this is a long question but the circumstances warrant it, I figure the more details (some probably even unnecessary) the more someone might be able to help March 2019 I bought two 12s5p batteries from Matrix. They use Samsung 30Q I believe (if not that 30C?). Had the dimensions custom spec’d into: battery one is completely flat with the BMS at one end making the battery a whopping 640mm long was originally intended for a drop down but that deck snapped, so I only put like 15 cycles on it before shelving it for 9mo and only using it three of four times in that times frame. BTW, don’t ever get a pack that long, it is near impossible to find a deck that it will fit under and even then your VESC needs to go elsewhere. Battery two is a nested double stack with the BMS at one end as with the first. That pack I used many, many times over the past 9mo, couldn’t even tell you the number of cycles but you can tell it’s aging as it doesn’t get the range it used to.
Both batteries had issues within the first month, both having gone “dead” due to a wire deep in the pack coming loose from the solder spot. So I soldered the wire back on and sealed it back up with heat shrink. USed the one battery , as I said, many times, and the other not so much. After breaking down my old board which was cracking I moved everything to a new deck and at the same time upgraded the motors. Along with the very inconsistent FlipShit VESC I have the setup ran fine for a couple days, then day before yesterday (while using battery 1 - the one not used very much and fresh off a charge) the damn thing just goes dead with no warning what so ever. Usually the board would start to lag power and get sluggish is how I could tell it was dying but I could count on one hands how many times that happened as I usually kept track of miles traveled and would charge it when the time drew close, trying my best to err on the side of caution - except those handful of times.
The following applies to both batteries currently, with only very slight variation, which is weird for them both to have the same problem when one is very heavily used and the other is brand new in comparison. Now when the board died suddenly the remote was flashing at me as if it lost contact, so I assume the VESC shut off - which didn’t make sense, the battery was pretty fresh. Now, the same thing happened with battery number two the night before but I never looked into it, I assumed it was because the battery was older so without thinking I replaced it with the other newer battery. Then after only one miles it died also. When I start troubleshooting it I find that the xt90 plugs have voltage. The charging leads have the same voltage. Now here is the strange shit I don’t get AT ALL. Battery 1, when I measured the voltage last night it was at ~47V. Later on after I tried to to power on the VESC which did nothing in response, not even an LED lit up. However I know the VESC works because I hooked up a 12V lead acid and the VESC powered on. Satisfied I immediately turned it off.
Ok, the battery voltage was 47V why didn’t it power on? I recheck the voltage and it reads~32V WTF!? In 10 minutes time and having tried to power on the VESC for less than 10 seconds the voltage now reads ~32V at the xt90 AND at the charging leads. When I try to charge with either a 1.5A or a 3.0A charger, nothing happens, the chargers will not turn on, they act as if it’s full or not plugged in. At this point I am pissed beyond belief and give up for the night lest I trash everything in reach.
This morning/afternoon, I check the voltages. Voltage is back up to ~44V. WTF? I check the other older battery, it is only at 37V, it hasn’t changed significantly but then again I haven’t been messing with that battery much. Immediately feeling the frustration returning I try the 1.5A charger: Battery one will not charge at all. Battery two will charge with a “teeter-totter” effect. That is, it will charge for three or fours seconds and turn off for one second. It will repeat this for about 15-30 minutes and then turn off completely, and I know sure as shit the battery isn’t anywhere close to charged. It still will not turn on the VESC, nor charge. In case it wasn’t clear, the newer battery charged fine the day before (1.5A charger) but then after it died suddenly it no longer charges at all.
Now I don’t even know what to do or where to turn. I’m considering trashing the motherfucker and getting out of esk8. I have loved the hobby intensely the past 2.5 years and still do but this is really getting fucking old… I’m so fucking mad with the problems with the FlipShit VESC and now this with the batteries. Does everything that comes out of China eat shit like this? Why have I been able to build four boards now successfully and now I can’t troubleshoot a god damned thing to save my life?
Anyone have any ideas why I am having such intermittent issues on something that shouldn’t be an issue to begin with? If nothing else why won’t the fucking thing charge? Should I try charging through the xt90 plug? Do I need to tear the batteries apart again and look for broken wires - which makes no sense because the leads all show the same voltage, I mean - what the fuck, seriously…?
Sorry for the rant guys, it’s just I’m at my wits end and don’t want to throw in the towel just quite yet but I don’t want to destroy the fucking thing either which IS going to happen if I can’t keep my cool.
