I’m thinking about making my own NRF Dongs from ebay or amazonian… The cost of Metr has gotten exponentially larger as my fleet has grown…
5 dongs $20 bux… some wires, a jst connector or two, some programming, and I’ll have 5 dongs for about the same cost as the brick hm-10
Programming is just dropping firmware onto them with st-link right?
Interested…
I’m watching Vedders youtube and it looks like you program these off the VECS and then regonfigure the pin outs for UART doesn’t look like rocket science… check Raf’s link above and follow it down… to the Vedder link
Never got my HM-10 modules working, tried several things but to no avail…
Never had problems with the Metr pro modules though.
Based on the conversation it seems like the HM-10 modules are causing trouble for some people but not others. @BuildKitBoards Can you comment on what the issue could be/ are we doing something wrong? That would be great!
EDITED: Changed my stance to be less confrontational. My bad. Wasnt my intention.
I’ll look into it, it’s likely some funky thing with the firmware. The ACK app hasn’t been updated in for ever (and every android app for that matter).
I still have multiple HM-10 modules in use, a couple from BKB. That is not a safe assumption.
Anyone got a fix for this yet? I mine went down after I updated the ESCs…should I revert to a pre-2.0 vesc tool?
Checked the iOS description for Xmatic and I guess we are stuck using 3.62 software? Is @twan still in existence to update the app or is there anyone else working on the app?
I got my board back together and redownloaded the app in anticipation of dealing with shenanigans to get the BT to work and lo and behold the app was able to spot plenty of bluetooth devices. I am assuming the the modules default tag is “BLE_NAME” or “HMSoft” I can open both up and see the default screen but when I try to do configuring I get an ESC not connected error and spamming the connect button in the top doesnt seem to do anything. Thoughts?
I used the 1.19 VESC Tool to get the 3.62 software on the ESCs, set them to UART and 9600 BAUD, and set the Xmatic app to look for HMSoft devices, works flawlessly on 3 different boards
Jared, anything to report?
Not yet, been strapped for time. Chips are genuine HM-10
I’m convinced bt telemetry via ackmonitor doesn’t work for vesc6 variant.
Ackmaniac last updated monitor for unity, which worked, but stopped working after unity firmware was updated (like 2 versions ago).
I have not been able to get it work for fesc6 at all.
Would you be willing to share VESC 1.19 and FW 3.62?
Sure, PM me in an hour and I’ll send it over email
