Broken USB port on DV6 and Can't Connect to Bluetooth
A couple of issues:
I stupidly broke the USB port on one side of the vesc, so I can’t program that side…
I have a bluetooth module from Makerx, but I cant find any installation instructions. Four wires come from the bluetooth module, but I can only find a 3 wire port on the DV6. So I thought (stupidly) that I could just use the three wires and not the green one. Now when I use the Vesc Tool, I can’t connect and it just keeps saying “Cant read firmware version. Make sure the selected port actually belongs to the vesc.”
So am I screwed?
The bluetooth module plugs into the UART port
5v → 5v
Gnd → Gnd
TX → RX
RX → TX
Pinouts should be on the ESC and module, you can also look at the all in one schematics on the forum
My apologies, but with the bluetooth I’m outside of my comfort zone. Is there something I can watch? Or a link with a step-by-step? I looked at the all-in-one schematics and I’m still a bit confused. I posted a pic of all of the wires that I have. And i dont know which of these are the uart port…
Capture
this is the uart port
u should use the 5V, GND, RX and TX pins to wire up the BLE module
Awesome. And when Im setting it up, do i program it by switching from one uart port to the other?
u technically don’t even need the BLE module, DV6 is internally canbus linked, u can just plug into the working usb side, and do the canbus forward button in vesctool, then program the other side
You only need 1 USB port. Both halves of the esc are connected via CAN. Press the can fwd button in vesc tool and it’ll switch sides.
Same with the bt module
If the BT module doesn’t work when you first hook it up, you may need to swap the tx/rx pins around.
But agree with others, you only need one side to connect and then you can program the other side over CAN. I never used to like doing it like that, but the recent versions of vesc tool seem to be pretty good with it.
now all we need is a one click button to auto sync to all connected vesc with current setting, then we r golden…well until they actually make HFI works also :joy:
Hi all! I appreciate everyone’s help so much!
I wired it correctly, but I’m still getting the same error code and it won’t connect? Are there settings I need to enable? If someone could help or point me in the right direction. I’m having a hard time finding the right resources.
Include the error text, maybe send a pic or let us know how it’s wired.
Try swapping TX and RX
But the best advice is here:
Just connect with USB to the other side
Oh, everyones advice worked perfectly! The board is up and running and it was a big relief. Thanks so much. I was just hoping to get the bluetooth up and running so i didnt have to keep opening the board to change settings. I will try to flip the wires. Thanks!!!
Ok, so I’ve hit a bit of a snag.
I programmed the board and everything was working well until i changed a few settings. Right now, I’m trying to run motor detection, but it keeps timing out on me.
I’ve noticed that I can write to the local vesc, but not the other. I can update the firmware on the local vesc, but when I switch to the other, it keeps saying “Erasing Buffer Failed.” Any ideas?
