Is there any way to fix this broken switch or is there an alternate I can get cheap and fast in europe?
If the metal part is not too deformed you can just put it back together
The white plastic sticking out of the metal part goes into the rectangular hole in the plastic part.
Then once it’s together you’ll need a drop of superglue on the edge of the two parts to hold it together.
Ah gotcha. I don’t think you can fix that ![]()
Is it a latching or momentary switch?
You can replace your broken one with basically any other switch (just make sure it’s the same latching or momentary)
