That looks boss, I haven’t had much time to get back to this last week but the cableing is coming together
I kinda wish I had the escs at each end haha so much less cable to run
I ran the power in sleeved braid under the grip. Could also work for phase wires?
Actually I hadn’t thought of that at all, it would be easy to recess that amount of material out of the deck and resurface it
I’ll try that on the second deck as a trial I managed to get the phase wires all soldered today and just have the sensor extensions left to solder and heat shrink
Then still got too do something about a box
But no doubt I’ll strap it all down for a test ride before that haha
Been a little while since I could put some more work into this project between everything going on but iv finished extending the phase wires, already had the 10 gauge cable same as the maker X uses to try reduce losses over the longer cables. An then extended the sensor harnesses for two of the motors to reach the midboard area
Will definitely be a fat stack of cables but hopefully keeps all losses and choke points to a minimum
Not the best pic update its getting dark here but here we go
