What a great thread. Quick question:
I see Fusion 360 but I’m wondering what another software you’re using for the electrical layout? Very handy to have components to scale and look like the real thing!
Ah yes, I know the struggle
. It would be a lot better it it had a percentage or directly the voltage. I also get some sagging so if you’re accelerating the measurement isnt even remotely precise
Total overkill, but I’m using Fritzing.
It’s intended to help place components and route connections to build custom pcbs, but I’m using it as a glorified ‘paint’ program. The latest version requires a mandatory ‘donation’, but you can easily find the previous release for free download (legal).
- PROBLEM - Riding in the dark is scary
- SOLUTION - Develop front and rear smart LED strips
| Purpose | Part | Details |
| Microcontroller | Arduino Nano 33 IoT | $19.99, MicroCenter |
| Level Shifter | TI SN74AHCT125 | $1.50, Adafruit |
| LED Strip | APA102 strip, 60 LED/m, IP67 in waterproof sleeve | $10.85, AliExpress |
| Silicone Housing | T1220 Flexible Silicone Gel Tube, IP67 | $11.55, AliExpress |
| Power Supply | 5V, 3.2A Step-Down Voltage Regulator D36V28F5 | $11.95, Pololu |
| Ambient Light Sensor | Photoresistor | $0.01 |
Front truck test:
What a build you have here! So peculiar and unique. Tiny improvements and details everywhere. I applaud you!
- PROBLEM - Catch all / finishing touches (ha)
- SOLUTION- Motor + Drive Covers
v1 modification of @poastoast 's BN M1 GD guards, printed in TPU
(extended length, cutout for forward facing motor cables)
Installed
After a quick 5mile cruise with the dog
v2 design update:
BnS [L] - 74XL v2.stl (229.2 KB)
BnS [L] - 74XL v2.step (189.4 KB)
BnS [R] - 74XL v2.stl (229.4 KB)
BnS [R] - 74XL v2.step (189.0 KB)
v3a / v3b design update:
v4 design update:
- SOLUTION- More robust charge port cover
v1 design draft
I keep stepping on my top mounting charge port cover and losing it on rides. Time for something a bit more snug.
v2 update (released)
*Adjusted the depths and diameters for a snug fit. Now, it works great! Borderline difficult to remove.
Hey there, I like your v2 improvement over the poastoast guards, they’re really pretty compared to the regular bash n splash guards.
I’m curious if you had any noticeable temperature changes with the guards installed? Any issues since you began riding them? Ever had a pebble or such get trapped between the cans and the guards?
Thanks.
Sorry for the delay, I didn’t see this.
That’s really what’s important A E S T H E T I C
I didn’t have any data before I installed them, so unfortunately, I can’t give you a comparison / temp delta. I’ve ridden through mud, puddles, dirt, sand… no issues so far. The last iteration are pretty open - they’re only protected on the bottom half, and made of flexible TPU, so I wouldn’t worry about debris.
Here’s my last ride (10 minutes ago). Was trying to do a max range test, but the battery wasn’t quite fully charged and I tapped out at 13% remaining. It got a bit sketch in the dark. Still working on arduino controlled auto-on lighting.
58C (136F) max temp trying to push it pretty much the whole time. No hills in houston, so I made do with speed as much as I could.
Small update - swapped straight cut gears for helicals. Excited to take this thing for a test drive today.
Posted a gear removal guide:
Also finally moved the smart lighting system from breadboard to permanent wiring. (Difficult to see, but there’s an arduino nano, a buck converter, and a level shifter in this photo lol)
Don’t think my terrible wiring survived on the front hanger. Only getting power to one section. Soldering led strips is awful. Probably need smaller gauge wire too.
What a spectacular build! Mandy thanks to you for documenting and sharing your problems and solutions - a real credit to what I’m sure was many hours spent troubleshooting and evolving your build. I hope you keep it up and continue sharing.
