Ok thats good. You’re probably right. I am planning on 83mm ABEC wheels but I could always change if I wanted to i guess.
I think everyone here would advise you to go bigger if possible. 85 is already too small for a lot of people here
Are you sure? Boosted has 85mm wheels and I like them. I was planning on having wheels for heavy torque and higher wheels for higher speeds
I have a board that came with 85mm wheels, and it’s fine. But I would never intentionally choose a wheel that small. I can use 90mm with the right mounts, but 100-120mm is a much better urethane range for clearance.
But end of the day, stick to your guns if that’s what you like.
Ok ill take your word. Ill go with the 90mm
